color Gradient over where particles are...not color over life
COW Forums : Trapcode
Beau Brotherton
on Mar 13, 2013 at 6:56:57 pm
Hi everyone,
I'm curious to see if anyone could help me create this look.
http://www.sharefaith.com/blog/wp-content/uploads/2013/01/churchcreativity....
Basically I'm wanting the particles to slowly change colors as they move from right to left. thoughts?? I know that this should be SO EASY!!! But I can't figure it out.
Beau Brotherton
-CS6 on a Mac-
Trapcode Particular 2.2
Mike Park
Re: color Gradient over where particles are...not color over life
on Apr 22, 2013 at 1:35:52 pm
why not use the particular layer as an luminence matte and then use a gradient overlay to provide the color. That would achieve the effect you are showing in the still image. Basically set up you particle movement using particular and set the particles to a mid gray with screen as the transfer mode. make another layer and apply your gradient. If you want the rainbow look, apply a linear gradient from right to left from black to white and then apply colorama and tweak you multicolored gradient. Then, use the transfer modes or track mattes to apply the gradient color to the particles.
Best,
Mike
