MIR or Form or....
COW Forums : Trapcode
Darrell Toland
MIR or Form or....
on Mar 7, 2013 at 12:03:51 am
Looking for the best method using MIR, FORM, AE only, to make a 3D moving terrain based on actual altitude or GPS/altitude coordinates. A wireframe model would work. Shaded would work as well but I'm not looking for lots of detail here. Any ideas would be greatly appreciated. Thank you.
Joseph W. Bourke
Re: MIR or Form or....
on Mar 13, 2013 at 2:36:57 am
I think your best bet, if you're looking for actual terrain, is to use a 3D program to import a DEM file (you can get these free from the USGS site. I believe Blender (a freebie) will import elevation maps. Then export it as a .obj file, in which case MIR, or Form will do the job. There may be other ways to get your elevation map to an obj, but these are the ones I know. I use 3DS Max to do the first step.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
Darrell Toland
on Mar 13, 2013 at 2:59:36 pm
Hey thanks Joe!
We don't have any real 3D programs here at work and my personal copy of Maya is to too old to update or even work on my current home OS. I do like your solution tho and will press for the purchase of a program as this could be something we'll be doing a lot of. I'll take a look at Blender. Thanks again!
D
Darrell Toland
on Mar 13, 2013 at 6:42:02 pm
Hey thanks Joe!
So for the time being, Blender will import the DEM and then export the obj. file?
Joseph W. Bourke
on Mar 14, 2013 at 1:52:46 pm
Hi Darrell -
Although Blender doesn't have native DEM import capability, here's a plugin that gives it DEM import:
http://uaraus.altervista.org/index.php?filename=en/content/categories/Blend...
Here's some more info on the process:
http://geography.lakeheadu.ca/bwilson/blog/?page_id=16
Joe Bourke
Bourke Media
James Mayo
on Jun 5, 2013 at 8:16:33 am
Hi Sir!
I have a problem with trapcode Mir, the first time i used it, a pop-up appears:
"Microsoft Visual C++ Runtime Library
Assertion Failed!
File:....Compcodegenerator.cpp
Line 1972
...at the end of the message:
(please retry to debug the application"
My Laptop's spec:
Windows 7 Home Premium
Intel core i3
Intel
graphic card: Intel Graphic Media Accelerator HD 1GB
RAM: 4GB
What is the problem and how can i fix it?
thanks so much :)
