Trapcode Lux- "Name starts with" not working
COW Forums : Trapcode
David Cabestany
on Nov 19, 2012 at 5:30:30 pm
I have a comp with two point lights, one came in directly from Cinema 4D, the other one I added in AE. I want Lux to react to the one light I added in AE but not the other one, so I renamed it to LUX TV, the problem is that when I change the setting in Lux to only use layers which name starts with Lux, the plug in stops showing (both lights are shut off), if I change it to anything, both lights are affected by it.
I eventually found a workaround by turning off the light I added and setting Lux to nly use lights that are off, but I'd like to understand why the other parameter is not working as it should.
Thanks.
