particular physics question
COW Forums : Trapcode
Tom Masters
on Nov 15, 2012 at 10:05:12 pm
I have a simple particle system set up where particles are coming towards camera (using air physics and a negative Z value for wind)
problem is I do not want particles to fly through the camera.
I would like them, as they approach, to fly to the side of the camera.
Is there any setting to create a force that repels them from hitting camera?
thanks
Mike Park
Re: particular physics question
on Nov 16, 2012 at 12:07:02 am
Kind of, you can use the spherical field option under the air physics to make them go around the sphere. put the center at your camera position and it should do the trick.
