Custom Sprite Split Clip Loop Problem After Effects Trapcode Particular
COW Forums : Trapcode
Sebastian Rasche
on Oct 18, 2012 at 4:50:01 pm
Hi Guys,
i looked through all the forums (creative cow, videocopilot etc.) but could find a fix for my problem.
I have the latest After Effects Version + Particular.
So have a comp with to different sprites set up. The comp is 2 frames long and the sprites are sequenced. so frame 1 sprite A and frame 2 sprite B.
No i wand to emit one at a time. The problem that i get is that it emits 1 of A then 3 of B, 2 of A, etc you get the point.
I want to alternate sprite A and B but cant figure out what I am missing. I turned everything which says random of so does anybody know why it is doing that?
I set up a simple ae-file so you guys can see whats wrong.
Thanks in advance.
4815_spritsplitclip.aep.zip
