Particular
COW Forums : Trapcode
Gianni Salvador
Particular
on Sep 30, 2012 at 1:20:02 pm
Hallo, is there a way to constrai particle to flollow a path?
let's say that i should make a sectional view of a stream of water flowing in a pipeline.
Mike Park
Re: Particular
on Sep 30, 2012 at 3:39:07 pm
Sure, just use the motion path mode. Create a new points light, name it motion path 1, animate it along the path. Did, under the physics tab, change motion path to 1. The particle should now be constrained to the past. Make sure you sent you emirrer point to the initial place of the light.
