Trapcode Falling Leaves
COW Forums : Trapcode
Steven Probets
on Feb 12, 2012 at 4:33:14 pm
I have created some falling leaves using Particular 2.
I cannot seem to get the correct speed settings to make the leaves rotate smoothly and gently.
They are all jumpy and move around far to fast.
I have changed settings but none seem to make much difference.
Can anyone recommend which settings I choose to make them fall slowly and pleasantly?
They are basically vectors and move around as if being 3D.
Mike Park
Re: Trapcode Falling Leaves
on Feb 12, 2012 at 9:39:15 pm
You should turn the velocity to 0 and use the gravity setting under physics. Turn it up to make them fall faster and down to make them fall slower. You can also mess with the spin and turb settings to give them a little random motion.
Hope this helps,
Mike
Steven Probets
on Feb 13, 2012 at 11:27:15 am
Thanks for the tip! I think I will need to restart with default settings. I have played with them so much it has become a bit to 'altered' (but at least I have learnt the functions!).
The client wanted gentle gusts of wind. What kind of settings would I be playing with? Key framming 'Wind' variables? I guess this would be more what the turbulence and spin functions are for?
Thanks again! :) This is my first proper project so thanks for being so helpful.
Mike Park
on Feb 13, 2012 at 3:12:18 pm
Here is a comp for you to look at and play with. A bit of a start so you can play with the settings and find the look you are after.
3679_fallingleavesfolder.zip
Best,
Mike Park
