How was this done?
COW Forums : Trapcode
Andrew Riss
How was this done?
on Nov 10, 2011 at 5:42:01 pm
http://reels.creativecow.net/film/ghosty-type
I know there is some trapcode form and some displaced type
any tips would be apprciated
thanks
andrew riss
Mike Park
Re: How was this done?
on Nov 10, 2011 at 7:08:57 pm
looks like particles and cc vector blur. You could use either form with a text map and displacement or particular to do this.
Basically, with particular, create you text, precomp it, make it 3d, use it as a source layer and have particles emit from it. Then, precomp that, time reverse it and add cc vector blur. There you go.
With form, use a precomped text layer as a matte for the particles, then animate a gradient wipe with some noise for the displacement. Then add cc vector blur.
Hope this points you in the right direction.
Best,
Mike
Andrew Riss
on Nov 10, 2011 at 8:19:20 pm
Hey thanks alot mike
the cc vector blur does the trick
-Andrew
