disperse particles in Particular like in Form
COW Forums : Trapcode
neshoi aban
on Nov 8, 2011 at 7:36:08 pm
Hi I'm doing a transition that dissolve the object like sand and blow it away, so far I've tried Form, but it doesn't have an option that would blow it away, then I've tried particular it's ok dissolving and blowing away by wind but the particles doesn't spread out like in the Form under the 'Disperse and Twist'. It just looks like the object retained it's shape, I want it to burst or explode out, thanks
Mike Park
Re: disperse particles in Particular like in Form
on Dec 1, 2011 at 7:49:52 pm
you need to add turb to the wind or spin when using particular. Also play with the spread parameters under the emitter settings. I have a tutorial on this site which demonstrates this text to sand or dust technique.
