map video clips to particles
COW Forums : Trapcode
Robert Mosner
on Oct 28, 2011 at 11:02:53 pm
I would like to map various video clips (20) to particles. Each particle would have a seperate clip playing. This is easy to do with stills, but I'm not sure it can be done with video clips. Any inputs would be appreciated.
Bob M
Mike Park
Re: map video clips to particles
on Oct 28, 2011 at 11:19:23 pm
Sure you can. Just make sure the clips arethe same length and put them in the same precomp. Then use the split clip function in the texture source and set the number of clips to your amount.
Robert Mosner
on Oct 29, 2011 at 10:18:20 am
Thanks Mike...I knew you would have the answer.
