How to offset the velocity of textured particle in grid emitter?
COW Forums : Trapcode
Diana Yuen
on Sep 14, 2011 at 5:24:03 pm
I have created a Grid Emitter which is 20 x 15, Any idea that i can animate the particle or offset the velocity of the particle from the beginning which like running out of the camera then and keep the ending frame back to a 20 x 15 arrangement? Just like the following effect
Mike Park
Re: How to offset the velocity of textured particle in grid emitter?
on Sep 14, 2011 at 7:14:33 pm
sure, just start with your grid and then shoot the particles at the camera. If you want them to start fast then slow down, use a high initial directional velocity and dial up the air resistance. If you want them to slow down as they approach the grid, simply use 0 velocity and then use the wind to make them blow. Then, simply precomp and time reverse the comp.
Diana Yuen
on Sep 15, 2011 at 2:14:23 pm
I am not so sure how to set it, can u describe more about it? thanks a lot!
