How to create starfield with Form
COW Forums : Trapcode
Shi Ky
on Aug 23, 2011 at 1:45:01 pm
Hi, I've been trying for a week to get this similar effect but I'm not having the same success. Trying to use Trapcode form.
Here is the great video: (from 27 to 36secs)
Any ideas or info to help? For the opening of the stars?
Warm regards.
Mike Park
Re: How to create starfield with Form
on Aug 23, 2011 at 3:39:46 pm
I personally would use particular instead of form. The first burst of stars would be easy with particular using aux particles for the trails. The second burst I would also use particular and use a high velocity coupled with some air resistance to slow them down. It also looks like there is some lens blur on the particles which changes over time. Hope this helps point you in a direction you want to go.
Shi Ky
on Aug 24, 2011 at 2:31:13 pm
Thank you, it's worked. =]
