Shine basics-creating an animated radial light ray effect
COW Forums : Trapcode
jim bachalo
on Aug 21, 2011 at 7:20:40 pm
Hi
Can someone suggest starting settings in order to create the effect in the background of this clip?
http://www.istockphoto.com/stock-video-14417728-fashion-words.php?st=2403a1...
Is it necessary to use Shine on an image with alpha, or can it be used on an adjustment layer by itself?
Local is the new global
Mike Park
Re: Shine basics-creating an animated radial light ray effect
on Aug 22, 2011 at 3:56:08 am
you cannot apply shine to an adjustment layer...it must be applied to the layer you want to use it on. Also, you dont necessarily need an alpha, shine uses the luma of the layer. I have taken the time to make a quick comp for you using only shine and after effects. It is not perfect, but it is pretty darn close. Take a look at the setup. It uses a masked layer with the roughen edges effect to create the column of light rays. I also made the runway lights using a similar technique. I would ordinarily use a different effect to do the lights, but did not know what plugins you had.
here is the file
2839_shimmer.aep.zip
Let me know if you have questions and I will try to help and explain.
Best,
Mike
jim bachalo
on Aug 22, 2011 at 12:22:05 pm
Thanks Mike
One thing I am stumbling with is seamless looping when using Shine.
Is there a simple way to achieve this?
