trapcode FORM - OFFSET option
COW Forums : Trapcode
pietro torrisi
on Jul 25, 2011 at 12:52:30 pm
hi there, i'm trying to obtain a certain effect using trapcode plug-in FORM.
I would need to create a grid with logos and would
like to create an OFFSET between the columns.
the images i attached show what i mean.
can't believe there is no way to obtain that!
please help...
Mike Park
Re: trapcode FORM - OFFSET option
on Jul 25, 2011 at 2:22:38 pm
The only way I can think of to do it using form is to use the Kaleidospace feature and offset the center xy in conjunction with rotating in z space about 43 degrees. I am not sure what you are going for. If this is just for a background, would it not be easier to use a precomp, offset and then motion tile the layer? Also, remember with form, when you move the camera around, the custom particle shape will always autorotate to face the camera. This may or may not be what you want.
I have attached a file for you to look out. It is CS5.
Harry Frank
on Jul 26, 2011 at 9:10:26 pm
Another option would be to use two layers and simply offset the second layer to position that alternate row.
Harry J Frank
Product Evangelist | |
© 2018 All Rights Reserved
