Particle spawning from same points
COW Forums : Trapcode
Robert Paynter
on Jul 11, 2011 at 10:55:14 pm
i'm creating a particle with a box emitter that live forever. It seems that the particles are spawning in the same spots way too regularly. I've change the random seed. But it still seems like they are popping up over top of each other in the same spots. meaning the new particles are covering the older ones in the same place. A lot .. I don't mind a few but it's almost like the emitter is birthing from the same postions on a loop. Is there any recommendations for getting them a little more random on birth?
Harry Frank
Re: Particle spawning from same points
on Jul 26, 2011 at 11:27:10 pm
One thought would be to add a little wind and turbulence, and increase the "Move with Wind" setting. You should get a continuously evolving set of values as the wind will make the turbulence (fractal field) move and change in relation to your particle positions.
__________________________________
Harry J Frank
Product Evangelist | RedGiantSoftware.com | Graymachine.com
