Particular complex explosions in true 3D
COW Forums : Trapcode
Stuart Brontman
on Jun 15, 2011 at 11:07:13 pm
I'm using the Trapcode training program for Particular (by Harry Frank) and was wondering if there is a way to produce complex explosions (similar to the one in chapter 10 of his program) in true 3D space. I'm trying to rotate around and through the explosion sequence, but this example from chapter 10 is made up of many layers. I'm not sure how to do what I'm trying to do - or if it's possible.
Thanks for any help on this.
Harry Frank
Re: Particular complex explosions in true 3D
on Jun 17, 2011 at 5:23:26 pm
Hey Stuart.
The explosion you are talking about should be in 3D space. Particular is a 3D particle system that reacts to camera movement. Make sure you add a camera to the comp and are using the comp with the Particular layers (not the precomped layers with compositing elements added)
__________________________________
Harry J Frank
Product Evangelist | RedGiantSoftware.com | Graymachine.com
Stuart Brontman
on Jun 17, 2011 at 6:56:08 pm
Thanks Harry. I'll give it a try. If I have any other problems I'll post again.
