Particular obscuration layer bug?
COW Forums : Trapcode
Kevin Cook
on May 19, 2011 at 7:06:56 pm
I'm trying to use the obscuration layer with some keyed footage. It works BUT...where my keyed footage is in "contact" with particular, my footage looks aliased/jaggy. I went through all of my other effects, turned everything off etc. and still the same jaggies. I went back to the keying effect and tried bumping up the edge softness and when I go back to my comp with particular, it's as if I did nothing to the key so I'm assuming this is within Particular.
Has anyone run into this? Thanks.
Mike Park
Re: Particular obscuration layer bug?
on May 20, 2011 at 7:16:45 pm
No, you are not crazy. This is a known issue with Particular. There are work arounds, the best of which is found here:
http://www.redgiantsoftware.com/videos/redgianttv/item/16/
You basically have to use 2 instances of particular and use the z depth feature to sandwich your footage in-between.
Hope that helps,
Mike
Kevin Cook
on May 20, 2011 at 7:28:13 pm
Awesome, thanks.
