Setting 1 particle per pixel gets strange result
COW Forums : Trapcode
Mike Throck
on May 2, 2011 at 5:43:56 pm
I'm setting up form so that each pixel of my comp has one form particle. Much like the text to sand tutorial by Aahron.
I'm getting these strange squares when I set it up, anyone know what I'm doing wrong?
Harry Frank
Re: Setting 1 particle per pixel gets strange result
on May 3, 2011 at 4:24:59 pm
That's an odd one. When I duplicate your settings, I don't get that pattern. Can you post the project just out of curiosity?
__________________________________
Harry J Frank
Product Evangelist | RedGiantSoftware.com | Graymachine.com
Mike Throck
on May 3, 2011 at 5:34:15 pm
I just create a comp (1280x720) create a solid, apply form and set the base form to 1280x720 and this is what I get.
thanks Harry
Mike Throck
on May 3, 2011 at 5:43:38 pm
I have another weird trapcode situation, and I know you work over at Red Giant now so I thought I'd show you. The problem comes when I apply Starglow to an adjustment layer in my comp. Once I do, AE doesn't recognize a layer (with time-remap-freeze frame) in a precomp. Even if I delete the adjustment layer with Starglow, the layer in the precomp doesn't come back. Here are screen grabs of without Starglow:
and WITH Starglow, notice the big hole in the guys side:
Even more interesting, if I apply glow to the adjustment layer before I add Starglow, no problem. If I deactivate the glow the layer disappears again and won't come back even if I turn the glow back on.
Harry Frank
on May 6, 2011 at 11:34:24 pm
I am forwarding this to support. It sounds like legit bug.
Harry J Frank
Aurora Ness
on May 11, 2011 at 12:04:42 am
Hi David, this is Aurora with Red Giant Support. I am currently testing for this issue and would love to get my hands on your project file. If you could please send in just your project file to Support@redgiantsoftware.com so I can compare it to my current project. Thanks so much!
Mike Throck
on May 11, 2011 at 10:09:53 pm
Here's a project file with the Form problem, I can send you the Starglow project as well if you like.
2326_formbug.aep.zip
Aurora Ness
on May 11, 2011 at 10:35:21 pm
Sure thing, if you'd like to post it here or to your case that would be great. Thanks Mike!
Aurora Ness
on May 12, 2011 at 12:02:59 am
Hey Mike, I just replied to your case but I thought I would post the solution here as well in case anyone was curious as to the outcome.
For you first problem with Trapcode Form, this was a bug that has since been fixed in version 1.1.1. Updating your Form should get rid of those lines and you should be good to go.
Cheers!
