enexplained transparency in particular
COW Forums : Trapcode
Kozo Okumura
on Apr 24, 2011 at 9:56:11 pm
I am working with Particular and some of my particles are showing up semi-transparent. However I have the Opacity set to 100% with 0% Randomness and with the Opacity staying constant over life. I also changed the visibility settings so that the Far/Near Vanish points and start fade points are the same. So why are some of my particles semi-transparent? Is there a setting I'm missing?
I am also exporting this as pict sequence with alpha channel, by the way.
Harry Frank
Re: enexplained transparency in particular
on Apr 25, 2011 at 3:37:23 pm
Depth of field?
__________________________________
Harry J Frank
Product Evangelist | RedGiantSoftware.com | Graymachine.com
