FORM tunnel
COW Forums : Trapcode
Ryan Turner
FORM tunnel
on Mar 2, 2011 at 10:50:03 pm
I'm trying to make an organic looking space portal or tunnel using Form, then fly thru it. I created a single layer sphere shape stretched out like an oval, put a camera in it and pushing forward on the cameras position. I thought this would work but it looks weird. I want to use Form because of the organic flow using the fractal field. Any suggestions? Or ideas for this using the Strings base form?
Harry Frank
Re: FORM tunnel
on Mar 2, 2011 at 11:09:52 pm
It's not easy, but if you are set on using Form, here's one way:
"Shape Layer 1" is simply a circle shape layer.
Otherwise, if you can use Particular, maybe try this:
http://people.redgiantsoftware.com/explore/presetdetail.aspx?presetid=771
Harry J Frank
Product Evangelist | Red Giant Software
Ryan Turner
Re: FORM tunnel
on Mar 2, 2011 at 11:30:29 pm
Thanks Harry! And the only reason I got this far was from your Trapcode Form Training video. Great intro tutorials to Form!
I'll try these settings now! Thanks again.
-Ryan
ashley brown
Re: FORM tunnel
on Dec 1, 2011 at 5:22:02 pm
Hey, im not new in after effects, id say im moderatley advanced, but im new when it comes to trapcode.
Is it possible you could make a tutorial, or a more indepth guid please? it would really help alot!
Thanks in advance.
