Expression to modify X,Y emitter position
COW Forums : Trapcode
Arnaud Paris
on Feb 20, 2011 at 1:07:23 am
Hello,
I'm trying to add a fixed 1500 pixels in X and 2000 pixels in Y to the emitter animated XY position.
The expression that appears by default in Particular for XY Position is 'effect("Particular")(5)'
I'm not sure how to tackle this.
If I add 1500 in the expression field:
effect("Particular")(5)+1500
I do get the X position offseted as I want, but I don't see how to offset the Y position with this kind of expression.
I tried:
effect("Particular")(5)(X,Y)
X=this.effect.position+1500
Y=this.effect.position+2000
But I get an expression error warning
Thanks for your help,
Arnaud
4K Red Digital Cinema in Paris
http://www.locared.com
Mike Park
Re: Expression to modify X,Y emitter position
on Feb 20, 2011 at 1:14:29 am
You need to add an array to the position. Try this:
effect("Particular")(5)+[1500,2000]
This should work. You can also use:
value+[1500,2000]
Value just reads the x and y parameters you put in and since it is a 2d array, you need to add an array of 2 numbers to it, hence the numbers in the brackets. If you want to add an offset to a 3d position, you would use "value+[x,y,z]" where x y and z are the numbers of the offset you want. Hope this fixes your problem.
Best,
Mike Park
Arnaud Paris
on Feb 20, 2011 at 1:39:52 am
Ah yes, that was the array! Thanks a lot Mike!
Mike Park
on Feb 20, 2011 at 2:52:42 am
You are welcome, glad to help.
