Installing Trapcode Plugin on a Mac in after effects CS5
COW Forums : Trapcode
christina rule
on Jan 26, 2011 at 2:27:15 pm
I've been trying to install trapcode in aftereffects but cant seem to figure it out. I followed the instruction on the install but couldn't find the files in AE. I did a bit of searching and realized that the files may be in the wrong location. After moving the files from the presets to the plugin folder I'm still having the same issue.... If anyone can help me out it would be greatly appreciated!
http://www.christinarule.com
Jim Scott
Re: Installing Trapcode Plugin on a Mac in after effects CS5
on Feb 2, 2011 at 3:49:04 am
The installer should put all the files in the right place. For the Trapcode plug-ins they would be found here:
Your Hard Drive>Library>Application Support>Adobe>Common>Plug-ins>CS5>MediaCore>Trapcode
Ralph DAgostino
on Feb 5, 2011 at 12:53:15 am
I'm on 10.6.6 and the only files in Common are
folders
9
10
11
and files
MediaCoreQTCodecRulesCS5.xml
MediaCoreQTDepthRulesCS4.xml
MediaCoreQTGammaRulesCS4.xml
Personal Dictionary MX.tlx
Harry Frank
on Mar 3, 2011 at 12:30:39 am
Make sure to use the "CS5" installer which is in its own folder when you open the installer folder.
Harry J Frank
Product Evangelist | Red Giant Software
Roshan Pradap
How to Installing Trapcode Plugin on a Mac in after effects CS5
on Mar 4, 2011 at 9:43:56 am
Pls give me solution....
