Bounce particles fall off plane
COW Forums : Trapcode
Jack Sewell
on Nov 1, 2010 at 7:33:31 pm
I have some Particular particles falling onto a plane using the bounce feature under the physics menu.
It works how I want except the particles seem to fall off an imaginary edge of the plane. The plane is enormous and easily covers the area of the particle emission.
Here is a still of the AE comp.
Any suggestions would be great!
Many thanks,
Mike Park
Re: Bounce particles fall off plane
on Nov 3, 2010 at 2:58:00 pm
Sometimes, the bounce physics do strange things. I see you have the layer set to infinite plane, which is correct. Try this, change the floor layer to none and change the wall layer to your solid layer and see if that makes a difference. Also, sometimes if you are using a layer, box or grid emitter, you set the z depth to greater than 0, you can accidently have particles being emitted below the bounce plane, which causes errors. Check those things and let me know if you are still having issues.
© 2018 All Rights Reserved
