can't line up particular emitter with afx's 3d space
COW Forums : Trapcode
Craig Huff
on Oct 31, 2010 at 6:14:42 pm
Hello,
I have a particular emitter box with 0 velocity on particles, so it actually forms a box out of the particles. I'm trying to have this particle box line up over another box that I've made out of 3d planes in After FX (this other box is pre-comped, with transformations collapsed), and then have a camera fly past them. However, as the camera moves towards the two boxes, they move out of alignment like they're at different depths, despite using custom view and orbit camera to confirm they're aligned. Any help would be much appreciated, thanks!
Craig
Mike Park
Re: can't line up particular emitter with afx's 3d space
on Nov 3, 2010 at 2:46:09 pm
Craig,
Not sure what the problem is. I just threw together a comp, just like yours with a precomped cube made up of 6 solids and then particular with the same settings for L,W, and H and it worked fine. What version of CS are you using and what version of Particular?
Craig Huff
on Nov 6, 2010 at 8:21:45 pm
Hi Mike,
thanks for your help. I have A LOT of precomps and I think some different aspect ratio settings between them was the culprit. Thanks,
Craig
