blizzard
COW Forums : Trapcode
dave reyburn
blizzard
on Oct 3, 2010 at 9:41:33 am
I've been trying to achieve the effect seen here
http://www.redgiantpeople.com/explore/presetdetail.aspx?presetid=449
with particular. I'm not having a lot of luck, anyone suggestions? I'f someone has an example file I'd love to pick it apart.
Mike Park
Re: blizzard
on Oct 4, 2010 at 1:32:38 pm
This is a pretty simple effect with particular. All you need to do is use a box emitter set to the size of your screen or a bit bigger, insert a camera, change the direction to directional, turn the velocity to however fast looks good to you, then adjust the spin and turbulence settings in the air physics rollout. Turn on some motion blur and adjust the particle size and you are done.
