random video clips in stead of random still frame??
COW Forums : Trapcode
Kozo Okumura
on Sep 20, 2010 at 9:37:58 pm
In partcular, I would like to generate bunch of video clips floating in the 3D space. I can do the same thing easily with still frame by assigning the particle texture to random still frame.
Can I do the similar thing with video clips and how?
Thank you!!
Mike Park
Re: random video clips in stead of random still frame??
on Sep 21, 2010 at 7:02:08 pm
You can do this. First, create a composition to house all of your video clips. Next, you are going to have to choose the length of all of your clips. Each clip MUST be the same length for this to work. Next, place your clips into the comp and sequence them. Now, put that comp into a new comp and add a solid and apply particular. Set up the particular parameters as you see fit. Then, under the particle type parameter, choose either sprite or textured poly. Next, choose video clip as your timesampling and use either loop, play once... and then set the number of clips to the number of video clips in your precomp. That is it.
