Magic beam/forcefield
COW Forums : Trapcode
Mikkel Buss
on Sep 18, 2010 at 12:43:41 pm
I´m making a movie in witch two magicians are dueling.
I want to make one guy shoot out a magic beam and the other guy making a forcefield around him a la the invisible girl from the fantastic four.
im using Particular and AE cs4.
I want to make the particles slide off the invisible spheare.
I can make a wall out of a solid and make the particles slide off that, but i´m kindda stuck on how to make it appear spherical.
Any good takes on how to Achieve this effect?
Mike Park
Re: Magic beam/forcefield
on Sep 19, 2010 at 3:18:37 am
The easiest way to do this is to use the spherical fields in Particular. Just adjust the position and radius to get it into the right place, then adjust your particle life or opacity to make the particles die off halfway around the sphere.
© 2018 All Rights Reserved
