Particular distortion problem
COW Forums : Trapcode
mike milyavsky
on Aug 27, 2010 at 3:29:57 pm
I'm having a problem using particular to build 3d roads:
I have a particle comp for the road texture which is about 200 x 10 and am using lights as emitters. Everything looks great and animates perfectly, as the roads grow out and around the "planet." However, for some reason at the most outward point in each emitters path there seems to be some sort of distortion. I really have no clue why this is happening and have tried rebuilding it many times as well as moving around the emitter path with the exact same results no matter what. Does anyone have any suggestions as to how I can fix this?
I have uploaded a reduced project here:
Any help would be greatly appreciated.
© 2018 All Rights Reserved
