Will Particular Preset pack work in CS5?
COW Forums : Trapcode
Mike Schmitt
on May 22, 2010 at 6:51:35 am
I've been installing my new plugs into After Effects CS5, and I'm wondering if anyone knows if the preset pack will work in the 64 bit application?
I'm going to give it a try after I'm done rendering a project, but I'd love to avoid having a crash!
Mike Schmitt
Re: Will Particular Preset pack work in CS5?
on May 22, 2010 at 3:57:40 pm
The answer is Yes, it works. Yay!
Haith Dinn
on Nov 3, 2011 at 8:40:02 am
I got the trapcode Particular Demo version and I have AE CS5. But trapcode isnt appearing in the effects drop down menu. Can you please help me here? What should I do? Appreciate it
Peace
Mike Schmitt
on Nov 3, 2011 at 1:40:44 pm
This may be an unusual reply, but: Do you have a lot of plugs in AE? I do.
On my system, at the bottom of the effects list is "Other." Go there and Particular is there.
If it's not there or in the list under Trapcode/Particular or Othere, Try opening your effects & presets window. Type in Particular and it should come up on the list there.
If it doesn't show up then, try reinstalling it.
It's a great plugin. I've had it a couple years and I've only really just started using it on everything.
Good luck!
