Need Trapcode Particular particles to rotate around in Z space
COW Forums : Trapcode
Jason McKee
on May 21, 2010 at 5:06:39 pm
how do I make my Trapcode Particular particles rotate around a central point in Z space like in this video (go about 8 minutes in)?
http://www.videocopilot.net/tutorial/energy/
Also using just CC Particle World and following this tutorial I keep getting an error saying "Bounce Animation not Compatible". What am I doing wrong? Thanks in advance.
-jm
Mike Park
Re: Need Trapcode Particular particles to rotate around in Z space
on May 21, 2010 at 5:31:12 pm
You basically have 3 options:
1. Since this is an output from a free tutorial, you can watch the tutorial and/or download the project file to see how Kramer did it,
2. You could create a camera and 3d null and place the null at the center of your particles, parent the camera to the null and rotate the null, or
3. If you have Trapcode Particular 2.0, you can animate the world transform independant of the camera to rotate the particles.
