Sprite vs. textured polygon
COW Forums : Trapcode
Robert Paynter
on May 17, 2010 at 10:04:44 pm
what's the difference? which renders faster?
Mike Park
Re: Sprite vs. textured polygon
on May 17, 2010 at 11:46:44 pm
The difference is that while sprites always orient toward the camera, textured polygons have independent 3d rotation. This means you can emit them and then rotate a camera around and they will remain oriented in the manner in which they were birthed...assuming you dont put any rotation on them.
As for which render faster...Not sure, but I would assume sprites would render as fast or faster depending on the settings, shadows and lights.
