Particle problems
COW Forums : Trapcode
Dan Archer
Particle problems
on May 13, 2010 at 12:54:39 am
I am using Particular to make floaty spots in space. I made a White Solid. Used particular with the Starfield Static 1 preset. when i go to the begining and set a KF i can rotate the particles in XY and Z, when i go to the end and rotate them to set my last KF, Nothing. I cant even see them spin. I can only see them move at the first frame of the comp. Also its a 2d layer. ANY help is great. Thanks n advance
A cut is a cut & a dissolve is a disolve, and not just anybody with a system is a pro.
Mike Park
Re: Particle problems
on May 13, 2010 at 2:41:37 pm
If you have Particular 2, use the world transform options to apply rotation to the particle system. Then it will work the way you want it to.
Spencer Tweed
on Jun 27, 2010 at 5:00:15 am
If you want them to animate across the screen check the 'physics time factor' as I think that in this preset that is set to 0 (which would mean that the particles aren't going to move at all).
- Spencer
