Turning a Moving Layer Into a Particle Mist
COW Forums : Trapcode
jeffrey fitzgerald
on Mar 2, 2010 at 8:13:20 pm
Thanks to Mike for your help on my last question. I just got word that my project needs to take a person on green screen and "dissolve them" into a particle mist that travels away.
My guess is that someone has done this? Maybe a tutorial online? Any thoughts are much appreciated...
Mike Park
Re: Turning a Moving Layer Into a Particle Mist
on Mar 2, 2010 at 9:50:56 pm
There are plenty of tutorials on this effect. Try looking under the trapcode section of the tutorials here at creative cow. You can either have the entire person turn into particles at once, where you will just use your greenscreen footage as a layer source, or you will have a more complex effect where you precomp your footage and then use a mask or an alpha channel to sweep across the footage, turning a small portion of your footage into particles over time to disintegrate the whole image.
Hope this is not to complicated to follow: I am a bit frazzled right now.
Best,
Mike
