Echospace headache
COW Forums : Trapcode
Gareth Hanks
Echospace headache
on Jan 28, 2010 at 3:58:19 pm
I am creating a web promo that's, ahem, inspired by the Apple iTunes 'flow view' look & i am using Echospace to create the reflection for each item.
I only have one instance of each item, a video clip, I am knocking the repeated item back in opacity & rotating it 180 on the z axis.
The problem I am getting is that I have an y axis instruction on the original item to rotate around it's ajusted anchor point so I can rotate it in a circle. When this comes out on the echospace created copy it reverses the y axis instruction & goes counter-clockwise to the original. If I rotate the orignal left, the copy goes right etc.
Any ideas? I am trying to look into the expressions on the copys/nulls to see if there is anything I can tweak but as I experiement there I'm seeking advice from my peers here.
Home - QuickSilver Duel 1Ghz 10.3.9 - 1.5 GB DDR SDRAM - 120Gb HD - AE 7
© 2018 All Rights Reserved
