Particular 2 - pre-run
COW Forums : Trapcode
Ed Blackford
on Jan 18, 2010 at 1:35:14 am
I was going through a tutorial and it used an older version of trapcode and in it you clicked options and you could set the pre-run %.
I can't find pre-run in the new trapcode. could somebody tell me where it is?
also what does pre-run mean/do?
Ed Blackford
Re: Particular 2 - pre-run
on Jan 18, 2010 at 1:47:35 am
i actually found it...
Emitter > Emission extras down at the bottom
Mike Park
on Jan 18, 2010 at 3:47:00 pm
Glad you found it. Pre run basically goes back in time and acts as if your particles were already born prior to the layer starting. For example, if you want some snow in a scene and want it in the process of falling at the start of your comp, you would have to make your particular layer longer than your comp and then push it back in time so that your snow fell into the scene prior to the start of the comp. With pre run, you dont have to do that. Just increase the slider and Particular calculates back in time and acts as if particles were emitted before frame 0 of your comp.
Hope that is relatively clear and answers your question.
Best,
Mike
Kereti Rautangata
on Mar 31, 2010 at 2:31:05 am
Hi there, It sucks how Trapcode changed things.
Its Under
Emitter/Emission Extras/Prerun
