Time Sampling?
COW Forums : Trapcode
Kevin Nelson
Time Sampling?
on Jan 8, 2010 at 4:47:50 pm
I'm attempting to create an effect with particular where I have 39 unique particles based on 39 1-frame stills, from a sequence - help!
Mike Park
Re: Time Sampling?
on Jan 9, 2010 at 4:10:05 pm
Kevin,
I think I know what you are trying to do, but dont think it is as easy as we would like. Common sense would suggest that if you have 39 frames in a comp and use that comp as a texture source for Particular, it would cycle through and use each frame until it starts using duplicate frames. Unfortunately, that is not the case. The only way I know of to control the frames is to use the new texture based on frame capability of particular. Set your particles per second to the frame rate of your comp and have particular emit until frame 39. This will emit one particle per frame and only emit 39 particles, each with a different texture from the source texture comp. I hope this makes sense.
Best,
Mike Park
Kevin Nelson
Re: Time Sampling?
on Jan 11, 2010 at 3:56:38 pm
Hi Mike,
Thanks for the tip. Everything goes according to plan until inexplicably frame 26 where Particular stops emitting particles - thoughts? BTW, what Time Sampling selection were you recommending?
Kevin
Mike Park
Re: Time Sampling?
on Jan 11, 2010 at 4:05:05 pm
Just the obvious one...make sure you dont have the pps keyframed to 0 at that frame. The time sampling I was recommending was "Current Frame - Freeze" which will emit particles textured with the layer you choose on that frame and hold that texture. It is the only way I know of to specifically control the order of the particles and not have them change.
Kevin Nelson
Re: Time Sampling?
on Jan 11, 2010 at 4:31:12 pm
Hi Mike,
I must have had a bogus setting somewhere, so I started from scratch and voila! Thanks.
Kevin
