custom particle bounce particular 2 help
COW Forums : Trapcode
Jessica Robbins
on Dec 3, 2009 at 8:20:57 pm
I am making a system of falling leaves with a custom partivle in particular 2 (sprite)- yet I cannot seem to enable "bounce" to make the leaves pile up on top of the floor layer?
How can you enable bounce in particular 2 with a sprite particle- or must this now be done another way?
Jessica
Mike Park
Re: custom particle bounce particular 2 help
on Dec 29, 2009 at 6:49:47 pm
Jessica,
Sorry,
Must have missed your post or I would have responded earlier. You need to make sure you are using the bounce physics, not air physics and create a 3d layer to use as a floor. You can use a sprite, but if you want a more realistic look with true 3d rotation, use a textured polygon particle type and adjust the random rotation settings. If you have anymore questions, let me know.
Best,
Mike Park
