Effect using Trapcode Particular
COW Forums : Trapcode
Dan Noel
on Oct 8, 2009 at 5:02:41 pm
OK folks.. need some help. I have a piece of surfing footage. When the gal in this surfing footage cuts through the water, the board creates a 'rooster tail' where the water splashes up and to the side, displacing the water. I want to embed a small small logo to effectively replace the water droplets. abnd I need to have the logos (hundreds and hundreds of them) track the surfboard as it cuts back and forth through the water. I know the mighty Particular is the right software.... but How do I do it? Really could use the brain power of you folks out there.
Mike Park
Re: Effect using Trapcode Particular
on Oct 8, 2009 at 6:00:33 pm
Well, you would keyframe or track the emitter to the movement of your board and then change the particles to custom particles and use the logo, and then, probably turn up the inherit motion from emitter parameter. Hard to tell without seeing the footage, but that is my best guess as a place to start.
© 2018 All Rights Reserved
