Can TC Sound Keys be used to affect the movement of a 3D object in AE
COW Forums : Trapcode
Scott Green
on Oct 2, 2009 at 9:54:02 am
OK, so I've made a 3D block in After Effects that I want to react to sound using Trapcode Sound Keys. I only want it to move along the Z axis though, not the X or Y axis. Can it be done and how do I do it?
I really do love good design - http://www.splurj.com
Mike Park
Re: Can TC Sound Keys be used to affect the movement of a 3D object in AE
on Oct 5, 2009 at 3:49:05 pm
Sure, this is really not a problem at all. I am assuming you know how to use soundkeys and set up the outputs. All you then need to do is set an expression to adjust the position of the axis you want. This is for a y axis setup
1 Create an adjustment layer, apply sound keys, set up the range and output it to the layer.
2 alt click the stopwatch of the position of the layer and type this in:
w = "pickwip to the output of the adjustment layer";
[[value[0], (value[1]+w), value[2]]
This will take the initial value of your y position and add to it the output from the soundkeys effect while leaving the x and z values the same. if you want to apply to x or z, just adjust accordingly.
Best,
Mike
Mike Park
on Oct 5, 2009 at 3:58:39 pm
I have uploaded a simple comp for you as an example.
312_soundkeysyonly.aep.zip
The music I used can be downloaded for free here:
http://www.sound-effect.com/sounds1/MMM_Loops/Happy_1.wav
Best,
Mike
