Stopping particles in Particular
COW Forums : Trapcode
Andrew Ruggles
on Sep 1, 2009 at 10:03:57 pm
I am admittedly a lousy Particular operator, but I'd like to get my particles to "explode" and then stop/freeze-- a sort of 3-dimensional ink splat. Here's a ref. of what I'd like it to do:
http://www.istockphoto.com/stock-video-7275303-ink-splat-zoom-transition.ph...
Even when adjusting physics time factor, I still get drift. Any help would be appreciated.
THANKS!!!!
Mike Park
Re: Stopping particles in Particular
on Sep 2, 2009 at 1:01:23 pm
You can use 2 things. First, you can use physics time factor, as you mentioned. Make sure it gets keyframed to 0, not negative. This will stop all movement - there should be no drift. The other thing you can do is turn up air resistance - this will stop particles assuming the number is set high enough.
Best,
Mike
Andrew Ruggles
on Sep 2, 2009 at 8:22:09 pm
Animating the Time Factor worked perfectly! THANKS!
