Psrticular 2 upgrade not installing
COW Forums : Trapcode
rob sonner
on Aug 7, 2009 at 2:51:08 am
Hi, just purchased a bunch of upgrades to Particular V2
I'm having sort of an problem scenarios where both end up in demo mode with the red x on the layer...
1) With and without Particular 1.5.1 installed it's housed in the Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Trapcode folder.
When entering the serial number the installer, it's still coming up in demo mode. Did uninsall, reinstall of V1.5, do the 2 upgrade, not happening on every system I try this on, and the ones it sticks in demo mode, I can't seem to get past this point.
2) Sometmes you have to go in and correct the permissions on both the Common folder as well as receipts so the installer doesn't fail. But at the same time sometimes it doesn't remove the old version at all, and says the install is complete Is there a hidden directory where the serial can't write but the installer is not reporting an error?
thanks, rob
Mike Park
Re: Psrticular 2 upgrade not installing
on Aug 8, 2009 at 5:23:10 pm
For this type of technical issue, I would contact Red Giant Software. They should be able to sort you out.
rob sonner
on Aug 9, 2009 at 7:37:40 pm
I have, no response from them
