water sprinkler effect
COW Forums : Trapcode
Joel Bialek
on Aug 4, 2009 at 4:34:18 am
Hello All.
I'm demoing Particular 2 to see if I can achieve a certain effect. I'm trying to simulate an oscillating water sprinkler. I have a directional spot light emitter set up and parented to a null for rotation. When the emitter is holding still, I have what I think are good looking velocity and gravity settings. However, when I rotate the emitter into the vertical, the stream of particles gets very segmented and unnatural(see below). The "position subframe" settings don't help at all. Is this just a limitation of the plugin, or is there a certain combo of settings that will do the trick?
Thanks ahead of time.
winXPpro 32
dual Opteron
4GB ram
quadro fx540
Mike Park
Re: water sprinkler effect
on Aug 5, 2009 at 3:00:40 pm
Not sure what the problem is there. If you use too small of an emitter, I can replicate the problem. Increase the size of your emitter on the z axis a bit and see if it fixes the problem.
Here is a quick project I made to try and test the problem. Here is what I came up with as my settings. Try it out and see if it will work for you:
© 2018 All Rights Reserved
