Trapcode Particular - Custom Particle Type Not Showing in CS4?
COW Forums : Trapcode
Julie Lee
on Jul 15, 2009 at 4:36:07 pm
I was looking at this creative cow tutorial: http://library.creativecow.net/articles/kramer_andrew/nano/video.php
And was up to the part where you have to use 'Particle 50' as a custom particle type. But in AE CS4, there is no option for that?
Mike Park
Re: Trapcode Particular - Custom Particle Type Not Showing in CS4?
on Jul 15, 2009 at 5:54:49 pm
Hey Julie,
Good question. From looking at your screen shot, it appears that your are using the brand spanking new Particular 2.0. I believe they renamed "Custom" to "Sprite" - kinda makes me thirsty. Anyway, if you are doing the nano tutorial by Andrew Kramer, you may be better off using the new "streaklet" particles, as that effect is what the new particle type is specifically designed to do. Any more questions, let me know.
Best,
Mike Park
Julie Lee
on Jul 16, 2009 at 12:09:28 pm
Oh, okay! I understand now - thank you so much! :)
Juan Hernandez
on Jan 7, 2010 at 9:00:20 pm
Awesome Mike! Thanks for your response...this is the exact answer I was looking for. Thanks for being awesome.
-Juan
David Biederbeck
on Feb 19, 2010 at 10:25:18 pm
Even when choosing sprite, I am not getting an option to choose which custom shape to use.
Any ideas?
Mike Park
on Feb 20, 2010 at 2:01:35 am
You need to go down to the texture rollout to pick the layer source. They just moved things around a little bit. If you go onto http://www.trapcode.com, they have some video tutorials explaining the changes.
Mike
Doog Vandi
on Sep 1, 2010 at 10:18:46 pm
You my friend are a God send. A big thanks and if you were a girl, lots of hugs and kisses :)
Laurel Guy
on Aug 28, 2011 at 1:33:36 am
Michael,
You are so on top of things... sure is fun having the details changed up, sure keeps things interesting... Hhaha
Mystery solved.
thanks much, Laurel
Rick Morton
on Feb 16, 2012 at 11:02:36 pm
Hi there.
In Andrew's tutorial on light sweeps.
In CS4, when I select SPRITE and select the custom particle layer, it does NOT do the same thing
the the custom particle does in the tutorial. In fact, you really don't see anything? The sprite thing
seems to work differently the the custom did. Any ideas?
Trenton Miller
on Dec 3, 2011 at 5:23:36 pm
When you choose sprite make sure you toggle the submenu "texture" a little ways under the sprite selection then click layer and you should be good from there.
Hope this helps you and everyone else :)
Tamim Faruk
on Aug 31, 2012 at 2:48:45 am
Hi! I'm using cs6 and I can't chose particle_50 from the the layer's list. Can anyone please help?
Ryan Dishongh
on Sep 24, 2012 at 8:20:59 pm
Heh.. I got a similar problem. When I select "Sprite" I then find my layer under the "Texture" tab. However nothing shows up. Anyone come across this glitch?
Adam Rosenberg
on Jan 10, 2015 at 12:51:42 am
I had the same problem. Try increasing the size. It's below the texture option
lorin crosby
on Nov 10, 2015 at 5:19:05 am
thank u!
Raghavendra Reddy
on Dec 9, 2013 at 2:35:16 pm
thanks dude....
nikaway melo
on Dec 22, 2014 at 5:13:07 am
Hello!
I want to do that effect, butterflies flying in a explosion in logomarca:
How I do?
