Particular particle stays in center
COW Forums : Trapcode
Mark Bigby
on Jul 11, 2009 at 11:49:18 am
Hello,
I'm new to the site. I have searched for this topic but was not able to find it. Sorry if its a duplicate.
I have been using Particular in several projects. After a few setting changes, the particle no longer moves. I'm left with a single particle in the center of the composition. The emitter still emits particles, but any expression or keyframe movement has no effect. It goes from working to stationary without changing any movement settings.
Any suggestions or help would be appreciated. Thanks.
Mike Park
Re: Particular particle stays in center
on Jul 11, 2009 at 5:27:15 pm
That doesnt make much sense. Have you purged the image cache under the edit tab. You may have some previously rendered frames messing you up. If that is not the problem, I would probably have to look at your comp since that does not sound like a normal problem. I am happy to help.
Mark Bigby
on Jul 11, 2009 at 6:03:37 pm
It also does it with CC Particle World (just found that out). It would work and everything would be great, then one setting change and it goes from working to stationary. I'll purge the cache and see if that works. Thanks.
