Animating drawn layers using particular
COW Forums : Trapcode
Benjamin Arthur
on May 9, 2009 at 10:23:42 am
I'm working on creating a animated ocean scene with waves. I have a layer of animated waves, and I used particular to emit these animations to create a moving scene, the waves loop and pass by the camera. My problem is that the wave animated layer particles keep seeming to pop up in front of each other in a jarring fasion. I need to set the emitter to emit the particles in a single direction so they don't run into each other, while keeping the random feeling of the waves, or find a way to keep the particles separated. any help would be much appreciated.
Neal Hammers
Re: Animating drawn layers using particular
on May 28, 2009 at 11:32:49 am
not quiet sure if I got the problem, but this far i guess you can emit grid of particles to have a sea-plane, and then animate waves inside precomp which was set as custom particle's source.
if this don't meet your need, then post some visuals, to see what exactly happens there.
cheers
