Trouble adding particular to 3D tracked scene
COW Forums : Trapcode
kenneth bonde
on Apr 14, 2009 at 1:51:33 pm
Hi
I have a shot, shot from a helicopter. The scene has been 3D tracked in syntheyes and is perfect. When the maya project is imported into AfterEffects all nulls locks to the groundplane as expected.
Now I want to add trapcode particular to one of the nulls.
- Adding a comp size solid as a 2D layer.
- Adding trapcode particular to the solid.
- Using expressions I connect the emitter positions to the nulls.
Problems occurs !
The emitter ends up some other place in AE 3D space, even if I try to rewire the x,y,z values differently. If I turn off the 3D camera inside AE - the emittre is there, but I need the camera.
If I manually move the emitter position to the null, the x,y,z values a totally different.
It's like the world size of the AE comp and particular are totally different.
Anyone been there and solved it ?
Any help appriciated
>kenneth
Jordan Montreuil
Re: Trouble adding particular to 3D tracked scene
on Apr 16, 2009 at 10:30:30 pm
I am also having the same problem. I want a light exported from Cinema 4D to act as my emitter but whenever the camera is active, the particles don't work. When I disable or delete the camera, the particles show up. Its almost as if the particles don't like the camera and run away when it comes up. I tried a test with a default camera and Particular works fine but it doesn't like Cinema's camera.
Any thoughts?
kenneth bonde
on Apr 17, 2009 at 6:41:22 am
Hi Jordan,
I got a reply to my question here:
http://toolfarm.com/phorumNew5/read.php?15,11948,11983#msg-11983
>kenneth
