water fountain
COW Forums : Trapcode
Jamil Yamani
water fountain
on Feb 13, 2009 at 2:21:15 am
hi all
i am trying to produce/create a water fountain effect using trapcode particular but i am bit uncertain as to how to go about doing it...would anyone know of a handy tutorial which may help me??
The Electric Canvas
Large Format Projection Specialists
Sydney, Australia
Glen Perez
Re: water fountain
on Feb 22, 2009 at 8:39:30 pm
bumpy
Andrew Ford
Re: water fountain
on Mar 18, 2009 at 5:14:21 pm
I am assuming you mean a big water fountain, like you would find in a park. You can get decent results doing something like the following:
The water in the bowl/base of the fountain can be created using Fractal Noise and Colorama on a solid, tweaked to your taste and animated with the use of evolution, sub offset, etc.
The spray of water can be done with Trapcode Particular using the sphere emitter. There are many settings to tweak here, but the main ones fall in the Emitter, Particle, and Physics / Air categories. Multiple instances of particular work well for each section of fountain spray.
There are a number of ways to show the water spray hitting the bottom pool of water, such as a combination of ripple, CC drizzle, ...even caustics. Good lighting will help the realism of this.
Jamil Yamani
Re: water fountain
on Mar 19, 2009 at 12:22:17 am
thanks andrew for the advice it makes good sense
jamil
The Electric Canvas
Sydney, Australia
