Rotation controls on Emitter in Particular
COW Forums : Trapcode
Eric Goldstein
on Jan 20, 2009 at 10:02:52 pm
I just started using Particular.
When I set keyframes for rotation in any axis (for instance 0 degrees on the first frame and 350 degrees one second later), I can see the effect of the rotation as I move the rotation control on a particular frame. But, when I scrub through the resulting animation, there doesn't appear to be any rotation, even though the readout by the rotation control indicates that the emitter is rotating.
Any help would be appreciated.
Eric
Eric Goldstein
Giraffe Film Company
Los Angeles
eric@giraffefilm.com
