Is there a loop point in a paricle animation?
COW Forums : Trapcode
Bob Cobb
on Jun 24, 2008 at 7:36:49 pm
Hi Folks,
I've been using particular for some time, and everytime I get a project that needs a loop, I have to do these chessy fades....
Lets say I hava a 15 sec particle loop of stars....
Is there a way to find a point in the timeline where a loop can be found?
graham smith
Re: Is there a loop point in a paricle animation?
on Jul 3, 2008 at 3:15:48 pm
i dont think it works like that
even if you dont change keyframe settings the chance of the same particles occuring again
are very slim.
just take a section thats say 12 seconds. take the last two seconds and add to the front. then mix this layer out from 100 to 0, and at the same time mix in the lower level 0 to 100 (do these at the same keyframes as each other) then using the velocity customize the mix with maybe one fading out quicker
than the other, believe me ive been using ae for 8 years and this is still the best kind of approach if
your making seamless looping sequences.
ciao
life is breathtaking!
Bob Cobb
on Jul 3, 2008 at 5:02:57 pm
Hey, Thanks for the info, I look and look and look for a loop point, TC needs to get on that....
I'll try your method, but the fades will have to do for now.
