Stray instances of custom artwork appearing with Particular
COW Forums : Trapcode
Russ Maehl
on Jun 7, 2008 at 5:17:06 am
I am creating ribbon type animations with Particular. I am using a custom artwork layer which is being duplicated to create the ribbon. Problem is with spurious instances of the artwork showing up. Seems to mainly happen when I change direction in Z.
I have a link to a snapshot. You can spot the 'oval' shaped artwork just at the type right if the path. Also included the makeup file.
Any ideas.
Jpeg:
http://www.box.net/shared/lff7om1icg
AE File:
http://www.box.net/shared/4oew4d2sc8
Ron Coy
Re: Stray instances of custom artwork appearing with Particular
on Jun 9, 2008 at 2:22:53 pm
i can't get the jpg to load, so I can't see what's up.
You might try the Trapcode forums at Toolfarm. The creator of the software hangs out there and answers questions about these kinds of things.
